The mysterious "Beam 200". It is a 5R beam moving head and is most similar (it seems) to the Elation Platinum 5R. These Beam 200 lights are everywhere at festivals and are Stage Techs go to light for mass quantity movers. I would be so forever grateful if someone would take the time to create this fixture with 16 channel mode.
USER MANUAL ATTACHED FOR REFERENCE
Can someone build fixture profile for this CHINA LIGHT? (manual attached)
mrgordon27
- Just started using FS
- FreeStyler Version: 3.5.5
- Twitter: twitter.com/djsolstice
Maunal%2Bof%2B5R%2B200w%2Bsharpy%2Bbeam%2Bmoving%2Bhead%2Blight(1).pdf- User Manual
- (404.61 KiB) Downloaded 225 times
mrgordon27
Re: Can someone build fixture profile for this CHINA LIGHT? (manual attached)
I will pay moneyzzzz for it!
perezdj
I will give it a try!
perezdj
See attached fixture. Please note that this fixture is untested.
Beam 200.zip- (23.84 KiB) Downloaded 190 times
blackbird237
Hi, very new to Freestyler.. actually only a day in.
I have a similar light to this, but it's the 230W 7R beam.
I installed this profile and it kind of works, but I cannot get the fixture to turn on.
What am I doing wrong??
blackbird237
My guide shows the light on at 128 and I changed that. Stil can't get the light to turn on other than the strobe effect.
- buttza
- FreeStyler Version: 3.6.4
Check the default setting on the strobe channel in the fixture file.
Make sure it is set to an OPEN Value. This might be the shutter by default too.
dbaplaya
I posted in another section and Rod kindly helped me but I thought I would respond to this post incase others can help as well. I also have a beam 230 and certain functions do not work, if anyone else on here has a similar light please respond, I would be most grateful.
