problem Monacor 510 windows 10. old version required
cleudio
FreeStyler Version: 3.6.2
Post by cleudio »
Hello everyone, I am new to this forum and I'm claudio.
I apologize for the English who will be incorrect since I'm using a translator to make me understand.
I have a problem with the current version of freestylers, 3.6.3, which appeared to me with the windows update 10.
in selecting the monacor 510 interface in my possession the program crashes.
the program is run as an administrator, and the interface works correctly with another Spartan program.
I read on a forum that with the previous version, namely 3.5.2 this problem does not occur. can you tell me where I can get this version? on the site there are no older versions available unfortunately.
if maybe you also know how to work around the problem that occurred to me, I'm open to suggestions.
thank you so much for the advice.
Claudio :fs:
cleudio
Re: problem Monacor 510 windows 10. old version required
Post by cleudio »
Still Good morning everyone.
On the forum I found the link of the old versions of freestylers and I downloaded the 3.5 and actually works seamlessly with the monacor interface 510.
I hope in the future is still not resolved the problem for sucessice versions, it would be a good thing.
so if someone has the problem with windows 10 with the old solution resolves.
of course in the old version there are no two universes.
Meanwhile hello.
if anyone has a solution I hope to communicate.
thank you so much.
Claudio.
pesca
FreeStyler Version: 3.5
Post by pesca »
Io ho lo stesso problema e attualmente uso la 3.5 con compatibilita xp sp3 su w 10 64
jrambo
FreeStyler Version: X2
Post by jrambo »
Hi, someone can upload the 3.5.9 please!!!, is the only version that works with my nanoKontrol2. A newer version does not light the korg leds...
thank you!
FreeStyler Version: 4.01
Post by Partyman »
you have to reprogram the nano keys with the korg software and change all keys to CC (control change) That was the way that I got them working for me. I have 3 of them
cleudio
Post by cleudio »
pesca wrote:Io ho lo stesso problema e attualmente uso la 3.5 con compatibilita xp sp3 su w 10 64
io alla fine ho reinstallato windows 7 sul computer e ora è tutto a posto.
tu sei un utente italiano?
jrambo
Post by jrambo »
Partyman wrote:you have to reprogram the nano keys with the korg software and change all keys to CC (control change) That was the way that I got them working for me. I have 3 of them
I already have all the keys in CC mode, I think the problem is Windows 7(64 bits)
In Windows XP the Nano lights works ok, but not in Windows 7 or WIndows 10 (both versions are 64 bits).
jrambo
Post by jrambo »
Solved!!! I forgot to set the MIDI Output in Freestyler settings...
maros336
FreeStyler Version: 3.637
Post by maros336 »
I had similar Monacor and I had the same problem on Win7 x64 until I installed version 3.6.31. It's the latest version in which its working fine with that DMX-USB.
Christian
FreeStyler Version: 3.6.3
Post by Christian »
Hello,
Monacor 510 is not working in versions after 3.6.31. I have the same problem like some other users too. Today I reported a bug in FreeStyler Bug Tracker and hope the problem will be solved soon.
Please let me know if you have got new experiences with this problem or a workaround.
Greetings
Christian
theotheotheo
FreeStyler Version: 3.6.31
Twitter: none
Instagram: none
Post by theotheotheo »
Hi, can anyone send me the 3.6.31 version ?
