Run cue from Windows command line Topic is solved
cyris
Post by cyris »
Hi Guys,
I've been using Freestyler for a couple of days now and I got my program working properly. The only 'problem' I'm having is that I cannot find out how to run my cue from a Windows command prompt. I just want to run my program once.
I'll briefly describe the situation that I want to accomplish:
- I'm using a UDMX dongle with a Magic FX Stage Flame and Freestyler X2, version 3.6.31
- The Magix FX works as follows: set channel 1 to 50%, then set channel 2 to 100%. After 1 second, turn of both channels. That's all folks :D
My cue runs this program in 3 steps. set channel 1, set channel 2 -> FLAME :twisted: , turn off both channels.
Can I create some kind of script that I can run to run this program just once?
Thanks for your help!
Kind regards,
Chris
FreeStyler Version: 4.01
Re: Run cue from Windows command line
Post by Partyman »
You dont need a script.
Just create the sequence, load to slot in cue window, disable loop cue option, create a keyboard shortcut to activate the sequence
cyris
Post by cyris »
Hi Partyman,
I did load my sequence into the cue window and I also created a button to run my sequence (and added a keyboard shortcut). But I would like to run that sequence without having to start Freestyler (manually), for example by starting my program from any sort of command line. Is that even possible?
Regards,
Chris
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
cyris wrote:But I would like to run that sequence without having to start Freestyler (manually)
Sorry I may be misunderstanding the question, but are you asking if you can send a command for freestyler to receive, and have freestyler generating a full dmx signal all the time without freestyler actually running?
Since launching the program on demand and waiting to load everything wouldn't exactly be very responsive.
cyris
Post by cyris »
No, the only thing I want is to fire a flame (for 1 second) with a "script" or "batch file" (in the DOS commandline for example).
So when that script is triggered, some sort of instance (or running service) from FreeStyler is loaded and initiates the flame.
cyris
Post by cyris »
Is it maybe possible to autorun a cue when Freestyler is started?
Regards,
Chris
Post by Partyman »
What I dont get is why freestyler has to be closed. Why can you not just have freestyler running?
No, the only command line options are /restricted that's all... @partyman he is referring to using the command prompt in windows a textual old skool way of doing things...
Post by Partyman »
I get that, just not sure why
automation, click this here it loads freestyler, auto plays your show job done etc etc
