Adding new fixture into existing light seq Topic is solved
tonym1
Post by tonym1 »
Hi
I have 2 Equinox Quadzilla's a Kam iLink laser and a Cubix 2.0 which all have sequences successfully programed in running on a Win 10 PC. I have bought 2 Stagg Headbanger 10's (Moving heads), which I can get to work fine in the Cue window.
The two problems I have are firstly, when I create a small looped sequence with the new lights and add it to an existing sequence it blacks out all the other lights!
The second problem is that if I have my Headbangers pointing horizontal to the dance floor, when I play them in the sequence they are at a 45 degree angle facing down. I go back to the Cue window and they are back to pointing horizontal again.
Any help would be greatly received as I have pulled out most of my hair!!!
dicky96
Re: Adding new fixture into existing light seq
Post by dicky96 »
Hi Tony
What method are you using to add the sequence for the headbangersto the existing sequence?
Rich
