I have made a cue with severel scenes and marked it as "Loop all sequences" and "Always start with 1st scene". Every step is a single step and does not loop. Running from cuelist works as expected.
Enter submaster.
First: when I OPEN the submaster window, while the cue runs, the color of some fixtures dissapears, don´t know why.
Second: when I start the cue from within the submaster it will only execute the first scene and then stops. Well, hitting run again, the SM will run the the first scene in loop, not the cue. Or just loops the first three sequences. Or other strange things are happening...
Third: I have to push run/stop at the submaster multiple times to stop the cue. Otherwise, it keeps running although the submaster cue window becomes white again.
Version 3.6.3, Eurolite DMX512, Windows 10
Thanks for supporting me.
submaster will not stop a cue Topic is solved
affenarsch
Re: submaster will not stop a cue
Well, found a solution for myself: I just switched to Q Light Controller+. Works like a charm!
Thank you.
Thank you.
