Chauvet Intimidator Spot Duo Profile Request Topic is solved
erico
Just started using FS
FreeStyler Version: 3.4.8
Post by erico »
Re: Chauvet Intimidator Spot Duo Profile Request
Post by Jan_K »
Have you been looking in the complete fixture library
viewtopic.php?f=23&t=4528
erico
Post by erico »
Yes. But also Im noticing some of the profiles are bad. For example the chauvet intimidators duo spot, and 250rc.
Post by Jan_K »
Fail to import or not working properly?
If not working then I think you can use them as a start and then modify them so they fit your needs.
Which one are you using of the duo fixtures are you using.
erico
Post by erico »
When I open the file Chauvet_Intimidator_Spot_Duo_20ch_1
Its an incomplete profile and it doesnt have the values for the gobos or colors.
Post by Jan_K »
I tried to import it and when I opened it the gobo tabs and color tabs was not present though I in the config tab could see that the gobo channels was defined.
When I restarted Fixture Creator and opened (Not imported) the fixture then all tabs and icons was there.
Is that the same you see
erico
Post by erico »
Nope when i right click and open with fixture creature. nothing shows
maybe send me the actual file. See if that works.
Here are the lights im using.. *highest Channels*
Intimidator Spot 255 IRC-13 channel
Intimidator Spot DUO 20 channel
American DJ Fog Fury Jett Fog Machine
send me what u have thanks..
Post by Jan_K »
These are the only two I have.
Chauvet_Intimidator_Spot_Duo_20ch_1.pff
(152.09 KiB) Downloaded 59 times
Chauvet_Intimidator_Spot_Duo_20ch_2.pff
(151.76 KiB) Downloaded 55 times
I don't know if this have any influence but I can see on the image that you are using Fixture Creator 6.1.
If the fixtures are created with a newer version then it may be the reason.
Djeargazm
Post by Djeargazm »
Hi, Has anyone found a final solution to a good set of profiles for the Intimidator Spot Duo 155 for both FreeStyler and Easy 3D? Thanks! Joe
