Where does import fixture file live?
jjbutera
FreeStyler Version: 3.6
I Use FreeStyler for: Band
Post by jjbutera »
I imported a fixture file (*.pff) just fine. I'm able to open it in the fixture creator/editor. I'd like to view the actual *.fxt file in a text editor but I can't seem to find it on disk. I thought it would be in the FreeStyler/Fixtures folder, but it isn't. The reason I'd like to view the file is because I want' to attempt to reorder the macros. There doesn't appear to be a way to do so using the editor. Where do the imported fixture files live?
jjbutera
Re: Where does import fixture file live?
Post by jjbutera »
Okay, I've got FreeStyler installed in my Program Files directory. Windows won't let programs write data after install into this directory. It actually writes to C:\Users\[username]\AppData\Local\VirtualStore\Program Files (x86)\FreeStyler\Fixtures folder which is basically also used as a source when the application is reading the Program Files directory.
TarbottonD
FreeStyler Version: 3.6.51
Post by TarbottonD »
You can modify the directory permissions on the Program Files (x86)\FreeStyler to allow the program to write into this directory, rather than the AppData\Local\VirtualStore location.
