I've worked on conventional lights and consoles for over 20 years - I'm comfortable with my knowledge in that realm - only moved into LED/Intelligent lights with the latest iteration of my band (the last 3 years or so). My fixtures are a mix of LED wash lights and 4 conventional movers. I have cues setup properly (move cues by themselves, then colors, then intensity, etc). Setup has worked great for me to use on stage with a program I wrote to control Freestyler called LiveCue.
I'm now going to be using our rig a few times as just a board op, and would like to setup a touchscreen interface to use. I've tried both touchscreens in Freestyler and I can't seem to set them up properly to run a live show well.
Would people mind posting screenshots of their touchscreen setups with a short explanation of how they use it?
Thanks!
Touchscreen Layout Examples
- FreeStyler Version: 3.5.9
- I Use FreeStyler for: Band
