Need fixture CAMEO hydrabeam CLHB400W RGBW
Lupo001
FreeStyler Version: 3.6
I Use FreeStyler for: Band
Post by Lupo001 »
I would need a fixture for CAMEO hydrabeam CLHB400W RGBW. I already built one in fixture creator that works so far that I can make macros for position and colours. But I can't use shapes for each head only for the first head.
thanks in advance
Martin/Lupo001
beatbomb
Re: Need fixture CAMEO hydrabeam CLHB400W RGBW
Post by beatbomb »
can you send me your fixture?
I will try my best.
regards
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Lupo001 / beatbomb Based on my understanding of the user manual here is my suggestion.
Physically configure the device to use 56 channels.
With Freestyler's FixtureCreator configure the fixture as a 14 channel fixture!
I've attached the user manual. Look at page 30 which specifies the function of each of the 56 channels. Notice that on the right side of the chart it specifies Head 1, Head 2, Head 3, Head 4. In 56 channel mode each head is assigned 14 channels. In the FixtureCreator define the 14 channels per Head 1.
When you add the fixture to Freestyler you will add 4 fixtures!
If you tell Freestyler to add 4 all at the same time Freestyler will increment the starting address for you.
If you add them one at a time you will need to specify the starting address for each of the 4 fixtures. The first fixture you add must have the starting address set to the value you configured the actual device. The second fixture (the second head) must have a starting address that is 14 higher than the first. The third fixture must have a starting address 14 higher than the second and the forth fixture must have a starting address 14 higher than the third. Example: if the first fixture has an address of 101 then the second fixture must have a starting address of 115, the third 129 and the fourth 143
I would do something in the text box so that it is apparent that the 4 fixtures are really a single device.
This gives you independent control over each head.
Hope I have not confused you. Feel free to ask me any questions.
Good luck
Best Regards
allmedia
Post by allmedia »
Having the same problem.
Is there available fixture for Hydrabeam 400?
Did you find a fixture file?
If not is this the fixture: http://www.cameolight.com/en/series/hyd ... 855jd0hf43
frank@singendonk.eu
Post by frank@singendonk.eu »
Hello,
I just started with FS.
I couldn’t find a fixture for the Hydrabeam 400
Is there available fixture for this Hydrabeam 400?
