Chinese RGBW 54x3W LED Par
jacobjb
Post by jacobjb »
Here is the fixture profile for Eyourlife RGBW 54x3W LED Par Can - This has been tested and is fully working!
I have no idea whether it will work with other Chinese RGBW pars but please feel free to give it a shot.
Hope this helps someone out :) :fs:
Led PAR RGBW.pff
(62.41 KiB) Downloaded 638 times
thiz
Re: Chinese RGBW 54x3W LED Par
Post by thiz »
Hi, I'm new to FreeStyler. I managed to import via Fixture Creator, and could find the fixture after that, but can't seem to have it working properly? Is this for the PAR 56 ones? It's the 54x3W PAR 56 RGBW cans I tried.
markfothebeast
Post by markfothebeast »
I have the Eyourlife 6x10w Par56 IP65 LED lights and I can't find anything for these. No manual/datasheet (or whatever). I'm confused by how to set these up!
icekola_99
Post by icekola_99 »
I have the new EYourlife 54x3W RGBW lights and this file does not work correctly for the newer fixture. I believe the new fixture is only 7 channel, but am having trouble reassigning to the correct channels to get proper functionality. Would love some help with this if anyone has had any luck! Thanks
halmir
FreeStyler Version: 3.6
Post by halmir »
i have the led par 18x18w rgbwa uv.....cane you halp....whit fixsture
Return to “Generic”
