Hi @ll !
i have a big problem by using the freestyler speed control. I want to use the OSC to Midi tool from " http://www.dmxcontrol.de/wiki/OSC_to_MIDI "
This tool generate a single not on/off (channel64 @ 127)in sync with the osc software (VirtualDj). So far so good, but this tool would not work with freestyler, because the tap-button in FS has 3 tap --> go, 1 tap --> off, 3 tap -->go, 1 tap --> off sequence. This was the only little thing to change in FS to work perfekt
sync to dj software. (over ethernet, too !!)
Please Help me to get the tap signal from "OSCtoMidi-Tool" work with FS.
Very big thx, greets
Stefan@BS-SoundandLight
P.S.: Freestyler is a very gr8 program !!!
OSC to Midi --> Freestyler-Tab-Button Topic is solved
Skyscraper
- djSupport
Re: OSC to Midi --> Freestyler-Tab-Button
If it works we'll add it on the forum...
