new shape Topic is solved
Crrispy
- Bug Zapper...
- FreeStyler Version: 4.1
Re: new shape
Select your fixture(s), open the Pan/Tilt window, select an existing shape, click "View" and you can edit it and save it with another name. You can also edit manually the numbers in the text files (.bez files in \FreeStyler\Chases) but of course it's a bit tricky.
bojan.cadjenovic
Re: new shape
i have all the time of this world mate.so you think i have to create coordinates for blue red and yellow points on shape wiev
Crrispy
- Bug Zapper...
Re: new shape
Yes, that's the idea for manual editing, but I would say it's only needed in special cases (see the topic on "waves" for example and the answer I got). You can check the existing .bez files for yourself. But in most cases you can use the visual editor and move the points with the mouse....
- djSupport
Re: new shape
Maybe someone could create a front end GUI that modifies these files seperatley from FS but gives you more control...Crrispy wrote:You can also edit manually the numbers in the text files (.bez files in \FreeStyler\Chases) but of course it's a bit tricky.
bojan.cadjenovic
Re: new shape
got it.everyone who want to try can open bez file with notepad and try to make koordinates
