few ?'s about scenes and cues Topic is solved
Djsynystr
first off i am new to dmx light but have been djing and doing mobile for 13 years. i use fs for mobile gigs only right now. i have made a few mini shows but i need to know if there is a way to have your lights go down the cue lists automatically instead of having to click each one. for instance if i have a few difference paterns built with like 10 steps each and have them lined up in the cue window how can i get them to go down the line automatically. 1st cue paterns then when its done move down to the next one etc. am i just doing it wrong or is clicking each show in the cue the only way to do it? thanks in advance.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: few ?'s about scenes and cues
Yes this is possible,
In the cue menu, click settings (looks like a folder & cog, at the top of the window) then select loop all sequences.
