New Laptop Topic is solved
krissherbert
New Laptop
Post by krissherbert »
Hey All,
Getting a touchscreen laptop to run FS on.
Just wanna make sure I copy everything over correctly, I have custom Gobo images, Custom backgrounds for Touch 2, and obi fixture files, along with shapes, sequences and overrides.
Does FS copy everything you add to its local directory?
Kriss
FreeStyler Version: 4.01
Re: New Laptop
Post by Partyman »
yes when using backup feature it should save all
krissherbert
Re: New Laptop
Moved it over. It didn't quite save all settings like sequence multi select backgrounds etc but most copied across.
Re: New Laptop
Post by Jan_K »
Hej
If it did not backed-up al settings then please report in the bug-tracker what failed so it can be fixed.
krissherbert
Re: New Laptop
I would but I can't log in to bug or feature request
Re: New Laptop
Why can't you log in?
krissherbert
Re: New Laptop
Says blocked or not valid. Using same user and pass as on here.
Re: New Laptop
Yes, it does not use the same system I'm afraid you need to register separately.
Re: New Laptop
The software that runs it has that limitation :(
