Hello,
i try to create a touchscreen on my windows tablet. There should be 20 buttons and one slider. It should be look like the layout in the pdf i attached. Each Button should have a size of 176x175 pixels.
Now i tried to resize the buttons in the FreeStyler\Images\Touch folder. But after reload the toucscreen file fts nothing happens. The size of the button is still the same (like the original button).
Does somebody know how i can change the button size?
Greets bjoern
Size of buttons in touchscreen
HennezMuc
Koordinaten Touchscreen-Layout.pdf- (130.74 KiB) Downloaded 45 times
krissherbert
Re: Size of buttons in touchscreen
When I've played with this if you resize the buttons and re-open Fs the buttons are bigger
