Chauvet Sweeper
suprdewey
FreeStyler Version: 3.5.7
I Use FreeStyler for: Band
Chauvet Sweeper
Post by suprdewey »
I Have a Chauvet Sweeper LED that does not seem to integrate well with FS. I can get the individual lenses to work fine, but it does not want to work with the S2l feature, it also will not blackout when button is pressed. same with the intensity sliders, they have no effect on them. Any ideas on how to get these features to work with FS?
Nathanrs93
FreeStyler Version: None
Re: Chauvet Sweeper
Post by Nathanrs93 »
You'll need to double check the fixture profile you've got for the fixture, make sure it's alright. If not come back and we'll help you in sorting it out, be sure to cross reference it with the manual
