Ben
Cuelts,Cue list tabs wont work with MIDI please HELP!!
liarschair10
- Just started using FS
- I Use FreeStyler for: Band
Ok here's what I have. I'm using Freestyler 3.6.31 and Enntec USB Pro. I have a dedicated lighting lap top and a dedicated audio laptop. I have everything worked out for both machines to communicate and it works very easily. I use a midi keyboard to assign notes to freestyler with , so while writing my light show i can just hit keys to tell it what scene to play and when to turn that scene off and so forth. That part works flawlessly,and also the assignment to override buttons also works very well. Here's the real problem. We are a band,so I wanted to audio sync our light rig to click tracks and some backing tracks. But i can't get the "MIDI" to control CUE TABS or CUE LISTS. I click learn for the devise to learn the notes,and it registers with the correct notes and velocity is at 127. Am I doing something wrong? Is this a setting issue or can this be done with midi? If not,it really should be able to,because if not thats gonna suck huge donkey balls... SOMEONE PLEASE HELP!!
Ben
Ben
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Cuelts,Cue list tabs wont work with MIDI please HELP!!
can you expand?
do cue tabs and cue lists work with your midi keyboard?
What software is sending your midi in sync with your click tracks?
is your midi sending both the required 127 followed by 0 command?
Matt
Matt
liarschair10
well,first off ..Hi Matt havent nbeen on here in a while,the band stays busy. Ok, so I have fixed the problem.,.it was my error. I had the wrong thing assigned in freestyler. However I did go in and change the Ini. file to midi not @80 so I didnt have to beat the piss outta my key board...
My audio software is Nuendo 4.
Thanks for the help Matt as always.
Ben
Ben
liarschair10
Oh,and I also had to change the "note on note off" in freestyler.. it wasnt clicked..
Ben
Ben
