Sound 2 Light Problem Topic is solved
tobi
Post by tobi »
Hey First my Setup:
I have FreeStyler 3.6.2 Running
and I have the ENTTEC USB Assembled Widget
My Problem is I want to use the Sound 2 Light Software to control my secquence.
But it does not work.
First thing is I don't have the button in Freestyler to start the S2L Software.
But I can start it if I run the exe File.
Then It works it detects Beats and recognizes the Sound. So far so good
But when I start a sequence the sequence doent react to the sound even if I have the little speaker active.
But when I go to a device and say "react to sound (random values) it works.
I don't know what I'am doing wrong can someone help me ?
Cheers Tobi
Re: Sound 2 Light Problem
Post by Jan_K »
Hej tobi
I don't have any experience with the S2L function but I am pretty sure that it will not work if you just run the exe file.
The button for S2L have changed in the latest versions and looks like this today.
It may be blue instead of orange.
