Hey, I have created this fixture library looking the manual to index the channels, I would like to know how to put the Prism and the Prism Rot according the manual and the Gobo Rot and Shake. May Magic 3D not dispays this functions?
Here is the fixture I have created and the manual of it.
http://www.muztorg.ru/news/cat_files/LS90.pdf
Thanks.
Big Dipper LED Spot LS90 Topic is solved
LucioCamp95
- FreeStyler Version: 3.6.2
Nathanrs93
- FreeStyler Version: None
Re: Big Dipper LED Spot LS90
If I remember correctly, then Magic 3D does display the functions as long as the fixture's are correctly made. You should have no problem, it will be like having the real fixture in front of you.
LucioCamp95
Hi, I've tested the fixture with that file and it has worked very well and haven't made any modification of it so anyone can use it for that moving head, thanks for the reply.
juanpablodeejay
- FreeStyler Version: 3.6.0
me ayudo mucho gracias
vsmario
- FreeStyler Version: 2.0
alguien podria subir el fixture de esta cabeza movil
visho
- FreeStyler Version: 3.4.6
amigos necesito con urgencia el fixture o saber que maquina funciona con los mismos canales que esta.
saludos amigos.
saludos amigos.
- FreeStyler Version: 4.1.7
I downloaded the RAR file submitted by LucioCamp95
This file is the packed fixture file created by the Freestyler Fixture Creator:
marcos araujo
- FreeStyler Version: 3.6.4
Can this fixture be used on moving head 90w sl90?
Manual link - http://www95.zippyshare.com/v/N2FiLRXD/file.html
