Robe Wash 150XT Topic is solved
proaudiomaster
Robe Wash 150XT
Trying to write a profile for this light and have issues with what to put in the 8 bit and 16 bit boxes. Any help would be appreciated. This is the first moving head light that I've tried. Uploaded owner's manual.
spud1511
- FreeStyler Version: 3.5.7
Re: Robe Wash 150XT
16 bit just means the pan and tilt have a 'pan fine' and a 'tilt fine'.
Otherwise you would find with a 540 degree pan for example that each 1 number you add to the dmx channel (0-255) would turn the light more than 2 degrees per digit, so your control would have no precision and slow moving sweeps would be really clunky/jerky movement.
Use 16 bit dmx chart. If you enter 'pan' as 8 bit, and 'pan fine' as 16 bit (then same for tilt) freestyler will do the magic stuff and make nicer smoother movements.
