fixture Topic is solved
andrew_onfire
fixture
hi friends..it's the first time I write here and I do not know if it's the right section ... I started with freestyle now. I have built a USB interface DMX based on FDTI chip and it seems to work ... but the problem is that I bought a lamp from china dMX (led small airship, it has 64 led 8ch) and I have not found a suitable fixture ... also not been able to create one from scratch ...could someone help me ?? thank you
- FreeStyler Version: Beta
Re: fixture
Hej Andrew.
Please upload the manual / dmx table else it is impossible to help you.
