Laserworld ES-400 RGB Topic is solved
Torpax
FreeStyler Version: 3.6.2
Post by Torpax »
Hello Freestyler,
i have modified a Fixturefile i found here in the forum to be compatible with my Laserworld Es-400RGb (I know i shout habe bought ILDa :-) )
Most of it works fine - but there is 1 animation counting backwards from5 to 1 that does not work
Sitting on channel2 with the value of 88 it shows only the 5 but does not count backwards like it does when i use a manual controller.
Any ide what i could do wrong?
Big thanks
Torpax
____________________German______________________________________
Hallo FreeStyler,
ich hab ein FixtureFile aus dem forum fuer meine Laserworld ES-400 RGB modifieziert.
Das ganze funzt so weit auch ganz supe,r lediglich mit den automatic programmen hab ich ein wenig probleme
Auf DMX Channel 2 sitzen auf dem Wert 88 eine animation die von 5 rueckwaerts zaehlt (es gibt weiter aber diese wuerde ich gerne verwenden_
ich habe den wert auf dem Gobowheel definiert. alle manuell sowie andere animationen gehen nur der Countdown bleibt bei 5 stehen und zaehlt nicht rueckwaertz.
Mit einem manualle Controller gehts be genau den selben Einstellungen.
Hat jemand eine Idee was ich falsch gemacht haben koente?
Vielen Dank
Torpax
Re: Laserworld ES-400 RGB
Post by Jan_K »
Hej I tried to open the pff file you have attached but it looks like there is an error in it.
There is not gobo tab and no color tab though they are defined.
You may have to export it again and eventually import it to see that the pff is created correct.
I will add this to the bug tracker
Torpax
Post by Torpax »
Hello Jan,
thank you for your reply, no idea what happened. I have exported it again and re imported it on my 2nd PC and it works for me.
can you give it a second try please?
Much appreciated
Torpax
Post by Jan_K »
Hej again.
It still don't work fore me.
And I have not got any response on the bug tracker on this issue.
I need to find an other PC and make a new installation for testing the this tab issue.
Back to you fixture problem:
You can open the DMX monitor and there you can see what values Freestyler are sending to Laser when you operate is manually and when you use the control panels.
You just need to figure out where the difference are.
Torpax
Post by Torpax »
Hello Jan,
thanks for the tip - there was no difference in the values. I managed to solve the issue by using another usb dongle (used the velmann before now entec) - seems like that fixed it.
Thanks for your support
Post by Jan_K »
Hej again
Nice to hear.
On the tab issue I found that you file have tabs.
I tried it on an other PC and there it was the same no tabs.
Debugging a bit on the issue it looks like if the fixture is opened / imported with a double click in a file browser then it fails, no tabs. But if I opens the fixture in FixureCreator -> Import then the tabs are okay.
I added this info in the bug tracker so Raphael can debug on it.
