Is it possible to start/stop sequences with different lamps parallel with each other? For instance having a club floor going on, while changing the sequence controlling the ledbars on the wall or the ceiling over the bar..
If this isn't possible, please help with ideas on how to do this..
Wishing you all a good evening/night
/Andreas
Run sequences in parallel? Topic is solved
- djSupport
Re: Run sequences in parallel?
yes, if I think I know what your referring too, click the cog on the cue window and select cue multi select always enabled
then select and stop more than one cue!
