I have lonly a couple of daysto finish a show using freestyler, for a tour my band will be doing. I have 10 individual rgb lights.
For every song I made a different cuelist.
For example:
*Cuelist 1* (triggered by cuelist button)
intro song 1 (static)
verse song 1 (fading steps)
chorus song 1(Fading steps)
bridge song 1 (fast steps, no fade) <-- PROBLEM
I have it setup so that i can trigger the cuelistbutton, so the right song(cuelist) comes on. I then switch trough all the different sequences in the cuelist. It's in the mode we're there is allways just one sequence active(if i start sequence nr 2, it will stop sequence nr 1, and the other way around.)
The problem:
when I make a sequence of 5 steps, with lowest fade(500) and fastest speed (100), it will have some sort of fading, but i need it to strobe. if i remember correct, it works perfectly if i go trough all the steps, but nog when i start the sequence mid song. all the lights look like they are stuck on 80%, when they are not strobing to 100%. If i manually click "dissable fades on the right of the cue, it plays perfectly, but somehow I can't store it in a way that it plays that way. (or is it possible to store settings like "go back to previous value, disable fades, etcetera?)
Help would be greatly appreciated!
Thnx,
Robbert
non fading sequences are fading, need help fast:)
reauxbeaux
- FreeStyler Version: 3.5.7
reauxbeaux
Re: non fading sequences are fading, need help fast:)
to be clear:
the lights don't go back to zero when they are strobing
spud1511
Ok... Usually led par's have a strobe function built in. If you post a link to the manual and the fixture file you are using then any experienced user (or failing that then me..lol) can have a quick check to see.
You can also select the setting to always start a sequence from the first scene (from the settings cog button in cue window).
If you really didn't have a standard strobe function and absolutely had to manually make a strobe-like effect you would want a fast USB - dmx interface (like 40 Hz) and a low scene time in the scene editor (maybe 100ms), and to click on the green word fade by the lights colour channels on every fixture for every step you are changing until it reads 'snap' instead (so no fade at all).
Eg.. Scene 1: all led par lights = SNAP - 100%
Scene 2: all led par light = SNAP - 0%
Just making sure the arrows to the right of scene name in the cue window are set to repeat the cycle.
- buttza
- FreeStyler Version: 3.6.4
Doesn't the FX Generator do that anyways?
