Last night i worked the first time with freestyler on a party. Every 10 or 15 minutes everything crashes down.
In my show there are 2 scanners, 2 lighteffects taurus van jb systems, 2 x 4 ledpars on a bar and a two colored lazer.
I use an 128 channel interface for all this.
All my adresses are correctly with information in my screen on the pc.
every thime it crashes i have to restart the system...
can someone help me please?
crash Topic is solved
- djSupport
Re: crash
1. Please post in the correct area of the forum and
2. It sounds like selective suspend USB port issue where your PC/Laptop decides that it will cut the power to USB ports after a set time go into your power settings and disable selective suspend for the USB and then your usb shouldn't cut out after 10 minutes.
