Question about the Submasters
ZeroProductions
FreeStyler Version: 3.6.2
Post by ZeroProductions »
Hi everyone, my name is Marco and i'm from italy.
I read carefully the support guide but I can't solve my problem: I made some cues and divided into 2 cuelists: the first regarding some par cans (i used the FX section), and the second with a couple of moving heads.
I would like to run at the same time the moving heads and the par cans, but with the submasters i can't do it, as one excludes the other. I read on the support guide that "If SM 1 has a moving sequence (like a shape) and SM 2 has a static position, both sequences will not run at the same time. Instead whichever sequence was
started latest will run.
" . I didn't got the point of this sentence; this means that you can't do what I'm looking for?
Thanks in advance :fs:
FreeStyler Version: 4.01
Re: Question about the Submasters
Post by Partyman »
one should not affect the other. Make sure in option you have cue multiselect checked
ZeroProductions
Thanks for the reply. Cue multiselect is already checked. This is what happens:
I run the "white flip-flop" for the Stairville Par 56 and everything works
Then I run one of the effect of the mini wash:
Now the Moving Head works properly, but the Par 56's do the flip flop effect but in Blue color, not in White. And this happens for all the cues.
Post by Partyman »
Sounds like you accidentally included the stairville in your miniwash programing. When open the sequence editor and have the sequence open, make sure there are no stars next to fixtures you do not want included. If you did include them you can right click on fixture and select to remove from sequence.
Rusty
