help to build a fixture file for led ball (rapid global chinese) Topic is solved
Scene Club
Post by Scene Club »
Hi there,
i´m looking for help to build a fixture for a led effect ball.
I tried it with similar fixures i´ve found for that ball but it does not work.
Also i tried to build a fixture by myself with the dmx informations in user manual but
there is no reaction in freestyler. Here is a link to the product:
http://www.amazon.de/GLOBAL-Lichteffekt ... global+led
please see attached the user manual with dmx informations of the product.
May someone can help me to put in the right informations in the right field of fixture creator?
I´m new in programming dmx fixtures, so i don´t know if the informations from manufacturer are
wrong or if i make a mistake by put in this informations in fixture creator.
Thank you for your time.
best regards
ledball_manual.pdf
(53.12 KiB) Downloaded 28 times
