problem with programmable overoverride button Topic is solved
FALCETTA
FreeStyler Version: 3.5.6
Post by FALCETTA »
Hello to all,
I have a little problem with the buttons override ,
I have created four scenes for 2 moving heads with pan and tilt movement , and strobe effect , I added the override button but when active moving heads remain stationary , and the strobe function works.
FreeStyler Version: 4.01
Re: problem with programmable overoverride button
Post by Partyman »
You cannot use movements (circles, rectangles Eights,...) with the override buttons. You can only use shapes in the cue window or submasters
FALCETTA
Post by FALCETTA »
but In Previous versions could be used
Post by Jan_K »
Hej
Just to be sure. You are talking about Bezier Shapes.
I have just tested it on the 3.6.1 and it works.
I made a sequence with one scene an "8" shape and added that to an button and it works.
Note: Only 1 scene in the sequences used on override buttons.
Post by Partyman »
If they do now work that is something that Raph must have just done, previously they would not work on overrides
FALCETTA
Re: problem with programmable overoverride button [SOLVED]
Post by FALCETTA »
With other versions of a freestyler I have always worked ( with one scene ) with the forms now it does not work anymore
Post by Jan_K »
Hej.
As I wrote above for me it works.
3.6.1 is the latest released version.
If you still have problems with it then I suggest that you add it in the bug tracker.
And note that it is something local for your PC as it works on Jan_K's PC.
There may be an interface which Raphl don't have 100% control over.
FALCETTA
Post by FALCETTA »
In previous versions it has always worked
