Two quick questions about freestyler...
Goochie
Hi Guys.
two quick questions..
1. if I download and install new version of Freestyler will it overwrite my existing shows?
2. does anyone know if new version has ADJ Starburst programmes within it?
Thanks in advance Guys..
Goochie
Goochie
- FreeStyler Version: 4.01
Re: Two quick questions about freestyler...
It will not overwrite your shows
No Idea about ADJ Starburst, Why not just make your own fixture file?
Goochie
Hi many thanks.
downloaded new version, didnt overide anything. great news
I have looked at creating my own fixture but it looks too complicated. tried many times. Done the you tube thing, tutorial thing but still cant work it out. Should be easy its only a simple 12 channel light.
Fixture creator wont let me get rid of gobo's?? The light doesnt have any..
Any idea's mate?
Any idea's mate?
Do not put any info in the gobo channel window and you will not have a gobo channel on the fixture. What is your fixture?
Goochie
its an ADJ Starburst
heres the DMX list within this manual..
Cheers
Cheers
Goochie
See if this works. It should work fine but not sure about the purple and yellow. You can open it in fixture creator and make any adjustments you like
Goochie
Cheers Partyman, much appreciated.
Total novice here, do I add that into fixtures folder in freestyler program? and how do I find it in freestyler once done?
Thanks again mate.
Goochie
Ive added it and it shows up in program files but not in fixtures on freestyler software?
is that because its not a .fxt file but a .pff file
Novice here as you can tell. ha ha ha
Thanks again mate.
Goochie
Goochie
Sorry forget that previous message, found it... useless twat sometimes me.
Thanks mucker.
Thanks mucker.
Goochie
Looks ACE, Will bring home the bits n pieces tomorrow night and wire it all up to try it out.
Many many thanks Mucker. IOU big time. cheers.
Goochie
Hi Partyman,
Again many thanks for your work on this fixture.
Most of it works Ok, but cannot get lamp on/off. Strobe is OK, Dimmer OK, but just can't get lamp to function?
Any chance you could have a look??
Thanks in advance..
Goochie.
Thanks in advance..
Goochie.
Not sure what I can do without the fixture but try this
dtwo
i couldn't get any of it to work. Pretty sure i have the SB in the right mode. I've made fixture files before, but this one has me stumped.
dtwo
Ok, so this is what i did. I had it set to address 192, which was next in the lineup, didnt work. Set it to address #1 and it works fine. so, now to readdress everything...
