From now I'm using a Midicontroller (15 Keys) for my Freestyler and I don't need to switch between my DJ-Soft and Freestyler using Alt+Tab all the time anymore. I would like to toggle the most important things directly vía Midi. The overridebuttons are working just perfect. With my cues I'm struggeling to find a good solution. Until now I had serval sequenzes for the pars and some for the movingheads. To be abled to run the MHs and the PARs in the same time I'd set "Cue Multiselect always enabled". I used to toggle the sequenzes with shortcuts and I could see always which one is running and which one not. Now Freestyler works mainly in the background so I can't see whats going on. Thats why it would be better to disable the Multiselect. I would use three buttons for different chases (sequenzes) for the PARs. This works but I can't use the MHs in the same time than. I've been fidelling around with different cuelists but they're not working independtely (even if "Keep Cuelist running" is enabled)... Then I tryed Submasters - this works nice as long I can see on the screen what's going on...I would need to many keys for go/back/start. Why does'nt start the next sequenz, when I hit "Go"?
The perfect solution in my case would be that the 20 sequenzes in the cuelist could be splited in two sections - independent by disabeling the Multiselect.
Is there a workaround for my problem?
groups of sequenzes... Topic is solved
