Hi, could you please add the ability to copy and paste multiple scenes in the sequence editor. This would allow the ability to create large complex sequences quickly and easily. Alternatively, would it be possible to be able to repeat a set of scenes a number of times within a sequence with out having to program each scene individually over and over again.
Thanks for all of your hard work!
Improved sequence editor
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Improved sequence editor
Hi its a great idea, and something I agree needs to be the next focus for improvement.
For now Go Monkey will allow you to create complex sequences including loops.
It works by creating simple sequences in freestyler then goMonkey allows you to combine multiple sequences to create complex shows.
