Hi all,
I have a slightly install unusual request and I wonder if anyone has achieved this.
This weekend I am doing a wedding. The couple would like some moving lighting outside on the trees. I had also planned to use cuelists rather than submasters for the lighting on the band/dance floor to make it easy for an inexperienced operator.
So the question, is there any way to have a chase running in the background for the external kit, which is not overwritten when a new queue list is loaded for the kit inside the marquee.
Does any one have any ideas or have you achieved something like this before?
Kind regards
Ben
Sent from my HTC One_M8 using Tapatalk
Running lights in different zones
bckeeping
Nathanrs93
- FreeStyler Version: None
Re: Running lights in different zones
You need to make sure that the external kit is not effected, when you program the kit inside the marquee. This means make sure it's not inside the programmer. Make sure to plan, program and play careful. Try not to go to hard with things, remember simple is better.
Good luck
Good luck
