Martin Acrobats Movement Very Limited Topic is solved
Ragnar35
Post by Ragnar35 »
Hello,
I can move my scanner beams from wall to wall, in any direction I want to. However, my Martin Acrobats are a different story - I can only move the beam pattern about two feet in any direction, at least, thats what I see using the Visualizer from Martin's LJ patched into Freestyler. Is this issue a freestyler issue or a Light Jockey issue? Any help would be appreciated!
Inverted Reality
Re: Martin Acrobats Movement Very Limited
Post by Inverted Reality »
Most likely a LJ issue (from what I remember they dont have a proper visulisation for the acrobat, but its been a bit since I used it).
The acrobat works with a full range of movement in Freestyler. One thing I did change about the acrobat personality is I assigned the barrel spin to tilt, that way you can fully animate them using the bezier shapes.
Didn't I make it? hmmm
