Hi guys,
I was wondering if somebody could "shed some light" on my situation,
I have 2 goldbright spiders, basically the same as the martin rush multibeam 2 effect...
The problem I encounter is when going between steps during playback as the colour is supposed to change say from red to blue, the jump is not insant, it cycles through green as if it were a colour wheel or as if you were manually pushing the slider of up and went through green, is there a way to avoid this transition? as it is an led fixture and my chauvet obey 10 does not have the problem between steps.
I see the lowest fade time between steps is 500, could it be this?
thanx
colour transition help
entertainmentevents
- FreeStyler Version: 3.5.5
spud1511
- FreeStyler Version: 3.5.7
Re: colour transition help
When you change the value of a channel look for the little button that changes from 'off' (scene your working on doesn't record a change to that value), to 'fade' (this will create a fade to the new value over the time period selected as fade time).
If you click on that little button once more it will go to 'snap' - so no fade at all, regardless what the fade time for the scene might be.
entertainmentevents
Thanx so much will try that, but what you describe makes sense , never really knew what those were for... till now will check it out and update...
