Fixture AYRA ALO 019 Topic is solved
pat.jj
Post by pat.jj »
Goedenavond,
Ten eerste wat een geweldig forum!
Kan iemand mij helpen een fixture file te maken voor een Ayra ALO 019?
Ik ben een complete leek hierin en heb geprobeerd via tutorials het zelf te doen, maar krijg het niet voor mekaar, op bax-shop.nl staat ook een fixture file maar daar klopt helemaal niks van
Het is een lowbudget scanner met 2 lichtbundels LINKJE: http://www.bax-shop.nl/led-lichteffect/ ... ed-scanner
Hoop dat er leden zijn die mij kunnen helpen,
Alvast bedankt!
Groetjes PAtrick
crazyboy1711
FreeStyler Version: 512
Re: Fixture AYRA ALO 019
Post by crazyboy1711 »
Same here. Could anyone create a fixture file for the "ayra ALO 019" fixture. It's a dual scanner. I too am a total noob in these things and i wouldn't know how to start.
Please help.
Thx a bunch !!!
grtz crazyboy
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Is this your instrument?
ayra_alo_019_dual_dmx_led_scanner_manual.pdf
(533.6 KiB) Downloaded 11 times
DylanR2005
Post by DylanR2005 »
Rod_Horning wrote: 18 May 2019, 11:09 Is this your instrument?
Yes, can you make it for me?
I will work on it. Have a house full of people for the next couple of days so it will take some time
2Can
Post by 2Can »
Hi There!
Have you already succeeded in making the fixture file?
2Can
I apologize. I have been absent from this forum for some time. I will work on it this week.
Attached is my attempt at a fixture file for your instrument.
After you select the instrument in the Freestyler work area click on Window->All
This will display the following helpful programming windows:
Custom Sliders
Macros (Lavender controls the LEFT mirror. Red controls the RIGHT mirror)
Your feedback and suggestions are encouraged.
Ayra ALO 019.pff
(57.63 KiB) Downloaded 19 times
2Can
Post by 2Can »
Is it possible to control it with sound2light?
I tought that the custom sliders were a problem for that...
I'm sorry but I have no experience with Freestyler's Sound to Light. Hopefully someone else can answer your question.
