Hi, I am using Akai APC20. Midi controller is working fine except when I map fader at controlling Submaster list change, then is not working well. On video you can see how is responding. When I map the same fader at intensity is working well so problem is not at fader.
Video link:
https://youtu.be/hfkYtxBkrrI
Thanks for you help.
Zdenek
upfaders react sensitively Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: upfaders react sensitively
hi
it all seems to work OK! no problem at all.
as you can add 20 sequences to a submaster so the velocity of 127 is divided by 20.
but is see what you mean, but on the otherside it can be a problem for other situations.
so if you can change the MAX velocity of the fader then you issue can be solved but can be a pain in the @$$ if you add a extra seq.
so 100 poeple and 100 differnt ways how people like it to work.
