i've a question by using Submasters in Freestyler.
I programmed my Lightshow by using the SM's.
When i want to run a SM's i push the start button. Than the first sequence is running.
But when i push the "GO" or "Back" button nothing happens?
When i click with my mouse on the next sequence it works, but when i push the "Go" button for next Sequence nothing happens? When i push the "Stop" button and then the "Run" button runs the next Sequence i've chosen with the up and down button?
My plan is to switch to the next sequence or back in the SM's fast on my Midi Controller. That works, i can go Up/Down in the SM's. But the next sequence doesn't start?
Can you explain me what i'm doing wrong?
Or isn't it possible and i've to stop every sequence to start the next selected?
Hap
