Hy guys
I started yesterday with freestyler and some lamps, and it is a lot of fun. But i have the Problem, that the par 56 (stairville) doesn't react to the "lamp-window" commands. I can only change the light intensity via the rgb window, and thats annoying, aswell as it is impossible to create a real strobe.
The manual says the strobe is on channel 5. I tried to change the settings in the FC, but without success.
Ironically the pars react to the general blackout command.
I created a fixture for a derbyeffect called Cameo Sunbeam, almost everthyng works as it should, except it doesn't react to the general blackout command. Does anyone know a solution or had a similar problem?
This is the PAR56 fixture: http://workupload.com/file/0LQaWsXx
This is the Par manual with channels: http://images.thomann.de/pics/atg/atgda ... ine.pdf#23
This is the fixture of the Sunbeam :http://workupload.com/file/DTt9zbSc
This is the Sunbeam Manual: http://adamhall.invaliddomain.de/out/me ... _IT.pdf#10
Thanks guys and gals
LED Par Strobe Channel doesn't work etc. Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: LED Par Strobe Channel doesn't work etc.
Hi
Ledpar:
if i read the manual i see that there is no Strobe channel. so that sucks!
channel 5 is a Speed channel for auto/sound mode
and DMX isnt fast enough to simulate a Strobe effect.
Derby:
the Master/slave icon is way to funny.
i dont see why the Backout doesnt work.
only you dont need to fill in the "lamp channel" value.
this is used to turn on / off a HID bulbs.
your light uses Led. so you dont need it.
Ledpar:
Derby:
gammagoblin
thanks for the info even tough it is bad news.
