3.5.9 Sucks [SOLVED]
kwelch007
FreeStyler Version: 3.5.6
I Use FreeStyler for: Band
Post by kwelch007 »
It loses all of my lights on channel 128 every 5-6 Cuelists I run. Everything else works fine. I restart FS and everything comes back just fine, for another 5-6 Cuelists. Then, I lose them. I can't revert to 3.5.7 during a show, but I will be tomorrow. I note that 128 is a round exponential of 2, but WTF?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: 3.5.9 Sucks
Post by buttza »
So this only effects the one channel?
Or does this effect the programs use after the 128 Ch fail?
kwelch007
Re: 3.5.9 Sucks
Post by kwelch007 »
As far as I can tell, this only affected the fixtures on that channel, although they span channel 128-144 (off the top of my head.) This is a critical issue for me, and if I could get a copy of 3.5.7 until this problem is resolved, that would be awesome.
kwelch007
Re: 3.5.9 Sucks
Post by kwelch007 »
The past versions website does not have any apparent links to anything but the current version.
buttza
Re: 3.5.9 Sucks
Post by buttza »
I think I might still have 3.5.7 I will check and let you know.
Re: 3.5.9 Sucks
Post by Jan_K »
Hej
I tried to upload 3.5.7 but is to large (17 MB)
If you have an email address then you can send it to me in a PM, then I will put the 3.5.7 I have in a mail for you.
Have you tried to monitor channel 128 with the output monitor when it fails.
Return to “Ideas and Remarks”
