Freestyler pan/tilt problem Topic is solved
mechanic
Post by mechanic »
Hi dear light people ;-)
I hawe problem with software.
Pan and tilt going without control. I put dot in middle and okay movingheads go in midle and after 2-3sec alone make one posaition, from left to right, etc.
Maybe i doing wrong in software?
:ugeek:
spud1511
FreeStyler Version: 3.5.7
Re: Freestyler pan/tilt problem
Post by spud1511 »
If you choose view dmx output from the menus at top of screen you can check what values are being sent from freestyler. If they are not moving then there is either (a) a timing issue between your pc to dmx interface and lights or (b) a cabling issue (no termination, mic cable instead of dmx cable, etc).
mechanic
Post by mechanic »
I try again and dont work FREEZE button?!
Moving heads again work automatic.
mechanic
Post by mechanic »
Maybe something w macros ?!
:fs:
mechanic
Post by mechanic »
Ok, i try termination is maybe, i dont put terminatore,.. thanx,..
mechanic
Post by mechanic »
Nothing move on dmx output window. Its not terminator, its not cable i try and wireless and cables.
Same thing, when i turn on freestyler and when only once move x/y dot, movinghead dont stop repeat one scene. :x
FreeStyler Version: 4.01
Post by Partyman »
I am really trying to understand what exactly your problem is. Your broken english is very hard to understand.
Are you saying that the lights are moving on there own without any freestyler input? Are you saying that you created a scene and it wont keep running? Please explain in detail what you are doing and what is happening.
Rusty
mechanic
Post by mechanic »
Oh, sorry for my bad english.
Ok, i start running freestyler, and all is conect, udmx, cables, moving heads, terminator.
So, frestyler work one scene alone without me, i can not freeze scene and create sequence.
I can not put beams in one dot or freze to make sequence.
mechanic
Post by mechanic »
start program-click on icon movinghead-put fader of PAN forom 0-28, or 0-30, whatever, after these movingheads work one scene x/y 20-30 sec and repeat same scene, without me, alone. ??
When i move x/y dot on middle, movingead go okay but this is ten sec. after these repeat again alone first scene, alone ??
Post by Partyman »
OK, I will ask some basic questions.
are you trying to create a scene?
