Does anyone have fixture files for 7ch 18 RGB par Led?
Have ordered them from eBay/Aliexpress and theres no brand name. Also have lost the user manuals, so dont know how to make a fixture file for them.
http://www.aliexpress.com/item/IN-PROMO ... 94059.html
Can anyone help me with this?
Stage light from eBay/Aliexpress
- FreeStyler Version: 3.9
Re: Stage light from eBay/Aliexpress
Did you ever make a fixture file ? I have the manual if you need it, i have one like this exactly that i am trying to get to work properly.
Were these any good?
- Just started using FS
- FreeStyler Version: 3.63
I suspect that most of the Chinese models run on the same DMX configuration. I have posted a Generic Chinese 7 channel for 36x1W LED fixture. Feel free to see if it resolves you fixture. It should be uploaded soon.
- FreeStyler Version: 3.6.4
They work just fine. I tried the Chinese model with the provided configuration and didn't had any issue.Debock wrote: 21 Feb 2017, 08:05Were these any good?donnieb wrote: 19 Dec 2016, 07:46 Did you ever make a fixture file ? I have the manual if you need it, i have gynectrol one like this exactly that i am trying to get to work properly.
will be set depending on the shipping time set for that item at the ordering stage ?
- FreeStyler Version: 1
Sound Active LED RGB Stage Lights Lighting Laser Beam DMX 512 Disco Party Club.donnibs wrote: 01 Sep 2439, 01:19 Did you ever make a fixture file ? I have the manual if you need it, i have one testogen bottle left like this exactly that i am trying to get to work properly.
