Hello,
I bought 1 month ago 2 cob4bar's, i dind't find good fixture files for this light on internet, so i made them myself. i followed the manual. in de file are following dmx channels possible:
3 channel mode: all led projectors the same collor when collor mixing
5 channel mode: all led projectors same collor / extra poer 1 & 2 controllable
6 channel mode: 2 by 2 projectors collor mixing ( led par 1&2 uses channel 1 2 3 / led par 3&4 uses channel 456)
8 channel mode: master dimmer / strobe / auto collor fades / rgb mixing all par's at the same time / extra power outputs controllable
12 channel mode: rgb collor mixing for each par individually
17 channel mode: macro's & auto collor mode, rgb collor mixing for each par individually , extra power outputs dmx controllable.
these files are tested en are working.
(this was the first time i made a fixture file)
jb systems Cob 4 Bar
clubfiesta
JB SYSTEMS COB 4 BAR.rar- (72.79 KiB) Downloaded 104 times
Nathanrs93
- FreeStyler Version: None
Re: jb systems Cob 4 Bar
You need export the file, so you can upload it in .pff format. Otherwise the file doesn't work correctly.
clubfiesta
the file is changed, i exported the fictures now it should be working
djchrizz
Thnx for the files,
1 thing is not right.
The strobe function is not fast.
I know the cob's has a faster strobe function.
Can you adjust it?
Thnx
Can you adjust it?
Thnx
