HI Freestylers,
I have tried to make a fixture for my old par56 Tbars.
These are DB-46 from Briteq
Can some one check if the Fixture is set up right please.
THanks
Rrara
BRITEQ DB-46
rrara
BRITEQ DB-46
db46.pff- (4.26 KiB) Downloaded 19 times
briteq db-46.pdf- (679.37 KiB) Downloaded 25 times
- FreeStyler Version: Beta
Re: BRITEQ DB-46
The fixture is correct.
However I will prefer to use 4 single par can fixtures.
The problem is with FreeStyler if you want to use the blackout function, then you need to define the shutter or dimmer channel.
In a fixture with 4 dimmers channels you can only define one channel as shutter or dimmer channel.
This means you will only have one of the 4 lamps switching off when you make a blackout.
If you use 4 single par can fixtures then each has a shutter channel and you can use the blackout function.
