Hi I am pretty new here and i am just starting to use Freestyler;
I tried to make a fixture for my Cob-4bars (i have 2 of them) but i am not shure i did it good.Can someone check the fixture please.
The manual is attached
and here is the try out.
Hope to hear soon where i went wrong or right.
Rrara
JB-Systems Cob-4bar
rrara
JB-Systems Cob-4bar
Cob4bar.pff- (14.42 KiB) Downloaded 52 times
COB-4BAR manual V1,0.pdf- (4.52 MiB) Downloaded 72 times
- FreeStyler Version: Beta
Re: JB-Systems Cob-4bar
Hej rrara
It is not bad and not god and it is probably working as you want it.
However there are some things which can make life a bit easier for you.
if you use rgb segments then each "projector" gets a color control.
http://www.freestylersupport.com/wiki/f ... t_tutorial
If I should have created the fixture then I would probably have done it as combined fixtures.
One fixture which only control one projector and then in Freestyler add 4 of them next to each other.
http://www.freestylersupport.com/wiki/f ... d_fixtures
http://www.freestylersupport.com/wiki/f ... ter_effect
This is always a question of what you think is the easiest way to control the fixtures and that way is for you to decide.
