Simple fade in/out Topic is solved
Gifron
Simple fade in/out
Post by Gifron »
Hello everyone,
I bought USB DMX cable on ebay and installed freestyler so I can control some of reflectors in theater.
I worked on theater mixer for last couple of years and I wanted to try something with DMX Controllers.
I manage to connect it and make everything works on my dimmers (there is only PAR64 and PC reflectors, with few LED's) but when I try to create simple fade in scene with some of my reflectors and I can't get it right.
Can someone give me some tips on how to create it using sequence option?
Regards,
Gifron. :fs:
Captain Ogre
Re: Simple fade in/out
Post by Captain Ogre »
I wrote a "how-to" on a different thread (above.) Take a look- it might help...
