Hi you.
I hope you can help me.
I am using Freestyler V2.96j (Non Beta) and i can't get the Sound to Light to change steps.
I can use the Random DMX Value, and it's is working fine, but when i change to Steps, nothing happends!
Best Regards
Thomas
Can't get react to sound to work with Steps
- FreeStyler Version: 2.96j
- FreeStyler Version: 4.01
Re: Can't get react to sound to work with Steps
Do you have a sequence running that has steps?
- DJ
- FreeStyler Version: 3.3.1
hope this helps,in the box where you select the sequence that you want to run you need to scroll to the right and uncheck the speaker icon which allows the sequence to be run by sound, theres a full explanation in the help files which can be acessed at the top of the screen
