fly on the wall Topic is solved
zeeeebo
fly on the wall
Post by zeeeebo »
i used to be able to select a fixture while running a sequence and move it to a position and it would stay there until I press release all button....
Now it doesn't, it just continues to play sequence and I can't manually take control of a fixture. Any ideas ? Is there a setting I have accidentally de selected?
surfvill
Re: fly on the wall
Post by surfvill »
This happened to me as well since I've upgraded to V.X2! After fiddeling around I found out that this behaviour, as you'd describe, start with executing the Sound2light-module... But this still does'nt cause the problem - once you klick away the window left hand side of the Audiowindow - there it is! From now you're anabled to use the faders of selected fixtures!
My solution: move the useless window as far left as possible. May this bug gonna be fixed within the next version of the X2.
