Saving current state
ferret-e
Post by ferret-e »
Is there an easy way of save current state of all fixtures? Or save changes made to fixtures after loading (running) sequence?
FreeStyler Version: 4.01
Re: Saving current state
Post by Partyman »
Under the edit menu you can save to favorite, startup or shutdown values
ferret-e
Post by ferret-e »
Thanks. Sequences, created once, cannot be edited online?
Post by Partyman »
yes, they can run. You just cannot have the sequence or submaster windows open or any cues running. I find it easiest to restart software then open the edit sequence window and you can do everything online.
