No fade on override buttons? [SOLVED] Topic is solved
surfvill
Post by surfvill »
If I start a sequenz (with one step) on a override button, the fade-in (set in the sequenz) will be ignored. It switches on immediately.
In my case: a selfmade spot for the mirrorball need to softstart otherwise the current protection of the PWM-Powersupply stops the procedere because the 24V/150W halogen bulb has a very low resistance.
I'd find a work around setting the sequenze as a cue. But that way I can't add the spot to the fixtures whitch react by pressing the Blackout button. I'm not using the build in Blackout - I'd create a own one for the override buttons. If I would - the Lamp doesn't fade in.
I hope Icould describe my problem clearly...
Is there a way to enable the fade for sequenzes on override buttons? Would it be a feature request/bug?
FreeStyler Version: 4.01
Re: No fade on override buttons?
Post by Partyman »
Hit the cog wheel at the top of the Override window and there is an option at the bottom to enable the fade
Rusty
surfvill
Post by surfvill »
Thanks for your response!
By hitting the wheel I only have the Options:
- 32 Buttons (4x8)
- add page
- insert scenes
- clear all
- highest priority
I'm running V.3.5.5 - shall I upgrade?
edit: I'd just install Freestyler X2 and it works great just like I've expected!
