LEDJ 5Q5 or 7Q7 RGBW slim par cans [SOLVED] Topic is solved
dazc1971
Sorry a second and final request does anyone have a fixture file fore the above either or both? creating files is new to me and last time I tried I failed miserably.
Thanks D
Thanks D
cupsidedown
Re: LEDJ 5Q5 or 7Q7 RGBW slim par cans
I would also like the same fixture as i am failing creating my own
spud1511
- FreeStyler Version: 3.5.7
Would probably help your case if you posted a link to the manual...
- FreeStyler Version: Beta
If it is a normal par can then this tutorial should guide you.
http://www.freestylersupport.com/wiki/f ... led_parcan
http://www.freestylersupport.com/wiki/f ... can:arc2_s
http://www.freestylersupport.com/wiki/f ... arcan:tour
If not then ask again so we can see where the tutorial fails.
cupsidedown
thanks Jan_k and thank you spud1511 for helping out trying to create the fixture for us
http://www.farnell.com/datasheets/1854337.pdf
spud1511
which of those lights do you have?
RGBA or RGBW? - that manual covers both
cupsidedown
Hi spud1511, 7q7 is the fixture that i have and they can be set to either RGBA or RGBW I would just like one RGBW fixture file if possible
spud1511
? RGBA refers to red, green, blue, amber - the colours of the actual LED's the fixture is made of. Same as RGBW is red, green, blue and white LED's.
You need to know which your fixture actually is, if it had both it would be RGBAW (it isn't), if you notice on the front page of the manual you linked to all the different versions of the light have different order codes, depending on the actual physical differences between them.
cupsidedown
Hi spud1511 I have looked at the fixture i have and the fixture is RGBW (Order code: LEDJ59 - Black (RGBW)
spud1511
Heres a quickly knocked out fixture for each.
Make sure your light is set to 7channel mode, if you need any improvements though you may have to make your own by tweaking it, or pay someone like djsupport (as he's one of the most experienced ppl I can think of at making fixture profiles).
You will want the RGBW for you light, I just threw in the other for the sake of it, in case it helps someone else in the future. Hope it helps
cupsidedown
thank you spud1511 for helping out i just could'nt get my head around it, i will test and get back to you to let you know the outcome
